Could somebody give me a general rundown of temperatures of a wood stove and chimney operations?
I know I should read the manual as every stove is different, but the manual does not give temp ranges...rather just fire sizes - high, medium, low, and over firing.
Now that I am up and running, I read a lot of posts regarding temps on pipes, and fire boxes....I have no idea what to expect, look for, or know. I asked around locally, and each shop said that the stove should handle the amount of wood (no hardwood available in these parts) that I can fit in is ok for the stove. After reading here, that does not seem to be the case.
What do you recommend for operating a Bennington cast iron -- double wall -- insulated pipe? The the double wall pipe I can't touch its so hot, the insulated pipe in the attic also is so hot I can't touch it (I inspected all during first few fires), and the insulated pipe outside is only warm to the touch, if that.
Just want to avoid a chimney fire, and damaging the stove. Do you suggest a thermometer on the stove and a separate one on the pipe? 18-24 inches up?
Thanks for the help!
Jason
Jason
