How well does a heat pump water heater in the basement during the winter? My basement walls are insulated.
Running a dehumidifer in summer isn't cheap.
If the temperature stays above 40, the heat pump feature will still work. I would think that it becomes less efficient as the temperature drops, but I'm not sure about that part. Mine's in a garage in Seattle, so it probably never drops below 50 in there thanks to our mild winters. Perfect location for a heat pump water heater I think.
typically) so it's normally around 55
