Both a continuation and refining of prior thread on stove top temps of the NC30.
Working to try and get the new 30 to provide heat at a similar fashion the the Defiant 1A it replaced. I have made changes to burning techniques based on feedback here and have been able to determine some ways to change the environment of the space to assist as well. House space to be heated is about 2000 sq ft., and is a Cape. Stove located at East end of basement at the walk in door. 20+ ft class A 6 inch pipe outside, with about 7 feet of single wall inside having 1 90 degree elbow. Was having trouble keeping the house over 65 during recent cold snap where lows were 18 at night with high winds. Biggest improvements so far were to use the blower and to segregate the basement into heated and non-heated area. Stairwell in the dividing point 60/40 heated/non. Last night loaded fully with coals to front e/w then 2 large splits e/w behind coals to provide even surface, then loaded n/s balance of wood. Went to 450 then shut down to 35% on primary air. 630 this morning it was 72 inside, 38 outside. Good result but softened by the increase in outside temp. Had most of the 2 logs left that were on the bottom row. Rearranged them and let them burn for an hour and loaded all large splits to hopefully burn slow all day as the temps are up in the high 40s today. Was going to put the Defiant back into service after fighting with the 30 for a week +, but I am going to await the next cold snap to see how the new methods work.
