Glass change in a EP 25
Jackfire
69
Vermont
HI: My side glass cracked i ordered one it came now im scratchin my head on what seams a easy install but lookin at it HOW DO WE DO THIS ?????????????????
I can't help you, I've no idea on this machine. But I can help to bump this request up to the front of the queue, to see if someone with knowledge will assist...
You just need to loosen the srews that hold the metal bars on the top and bottom of each piece of glass then pop the glass out.
Hope you ordered new gaskets with the glass.
Reactions: Jackfire
Your manual should or might have some details or diagrams. If not research the web and / or you could always call Englander's customer support. Might want to get some Anti-sieze and the threads of the screws when you run them back in. As directed by Bioburner here and others Anti-sieze is cheap and a very good friend to a stove owner.
I'm surprised my PC45 didn't change colors to silver I hit everything so much with it. Just a cheap and easy solution for the "IF" you ever need to turn bolts on it in the future. The rope gaskets can be found many places as long as it is the right diameter.
This may be the correct manual for your stove, look on page 55 for the exploded door parts schematic:
(broken link removed to http://www.heatredefined.com/assets/images/manuals/3343/25-ep_epi_merged.pdf)
Or find your correct manual here:
(broken link removed to http://www.heatredefined.com/support/owners-manuals/)
Reactions: bags
