Glass gets black
AppalachianStan
557
Clover SC
Hi guys, My glass gets copper then black. I am pretty sure it is the crude air wash on my older stove. I had it up to 650°F yesterday but it did not burn the stuff off the glass.
1.) Was this a problem with the older cat stove?
2.) How do you keep the glass clean? The ash cleaning does not work at all.
Simple. It is in the fuel you burn.
Try some good creosote remover and a razor blade. This my second with my insert and the first year I had a problem keeping the glass clean but this year I got it and the glass keeps clean(er). I think keeping the smoke off the glass helps and to do that, keep the temps over 400 degrees most of the time and the box itself will keep the smoke will burn off. Burn most of the wood to coals before adding more wood and use cured wood and get and check a moisture meter that your wood is less than 20% (Harbor Freight has them for about $13.00).
Robert
If you wood is dry, I find that just leaving the black on for multiple fires will eventually begin to break up the black for easier cleaning. Trying to clean fresh brown/black seems harder for my stove. Cheers!
When I had this problem last year I removed my door and took it outside, then I used oven cleaner to remove the black. This year I am burning real seasoned wood. I don't have a problem with black glass now. I'm not trying to be rough on you but unless this is a real old stove or it has poor airflow characteristics the blackness comes from unseasoned wood or burning too cold.
The wood is 1 1/2 to 2 years old. My wood looks to be mostly Maple. I am burning in cycles load it up burn it down to coals about 300°F reload. In the mornings I have been topping out around 600°F, but up in the days I have been burning at about 350°F to 400°F just to keep it warm in my house. During the day anymore heat than that it will run you out of the house.
from another forum on here I started using wadded up newspaper to wipe the ash and light smoke that gets on mine. a good wipe once a week keeps mine super clear. Even wetting the newspaper works. Then I just throw it in the insert. Of course I do this in the morning when I'm reloading and the stove is pretty cool. Wouldnt recommend throwing cool wet newspaper on the glass when it is hot. Even tempered glass could break.
mellow said:
As we see from the BK owners, you might still get dark glass even if/when you put cats in that stove.
I know it is a older stove but now that it is burning as good as it is. I am thinking that I will put the cats in.
It may just be a weak design. A lot of early air-wash systems were poor performers. Good to hear that you are staying warm at least. Sounds like the cats are about to be let out of the bag. Let us know how it works out.
Dry fuel can turn glass black. Smoke burns in the cat, not on the glass where it can accumulate.
I've got a firebox full of smoke when downdrafting. Glass can get darkened pretty good on a burn with no primary air. But that smoke doesn't leave the box unburned if things are working right.
Oven Cleaner works great if you want to get rid of it.
And my stove hasn't got an air wash. I suspect yours doesn't have a great one either.
I just got done cleaning the glass this time was the hards tiring to get that stuff off the glass. I will try Rutland glass cleaner see if that helps next time. I have tried vinegar, ash and newspaper, ash and wet newspaper, class cleaner, razor blade, and have tried after clean using cooking spay to make it easier to clean the next time.The best has been dish detergent mixed with hot water and a Scotch Brit pad. This time I used dish detergent mixed with water and a razor blade. That stuff was baked on.
I like "Greased Lightning".. Its available at the dollar general stores and is cheap.. When cold I spray it on and scrub it away with a good paper towel.. As others have said, burn hot and keep it up and you might just find out it will get flaky on its own.. Mine does, sometimes it takes a week but its a lot better clean when you don't use chemicals.
Jason
I would be aware that some ceramic glass does not like some chemicals (ie ammonia seemed to leave a residue on mine), especially when the glass is warm. The only thing that worked for removing the ammonia stain for me was the Rutland cleaner. But if you have scratched and etched your glass already, all bets are off.
Troutchaser said:
[b]Dry fuel can turn glass black. [/b] Smoke burns in the cat, not on the glass where it can accumulate.
I'm in deep trouble with all our dry wood. But we won't tell that to the stove...
With a BKK cat stove(or most cat stoves) on low cruise you won't have much air going over your glass.
I do believe you wont have it happen as much with a tube stove.
Smoke is out gassing..all wood no matter how dry will out gas..IE: SMOKE!
Glass is way cooler then the cat.
Glass cooler with a cat is right. That does not mean the glass will turn black though. At least our glass has not turned black. Exception was during initial burn-in. Got a bit black then but disappeared on next fire and has not had any black since.
You sir probably have a really good air wash system..BKK..not so much.
I believe it has to do with airwash. My Buck 91 get smoked up in the lower right hand corner. Flawed airwash says I.
Other than that I love the 12 to 14 hour load with the 4.3cu ft cat firebox!!!
What gets burnt on mine will not burn off with 2000 degree catalyst temps....go figure..
Razor blade works wonders.....
David
David
That's all you get out of that size box..you can't be talking shoulder season.
10 fer on the razor blade scrapers!
I don't know that I would be spraying cooking spray on it and baking the oil into ceramic glass. I have an older oven that I had tried every chemical known to get the baked on junk off the glass. Ash, newspaper and a whole lot of elbow grease was the only thing that finally worked.
Dennis, I'm not saying that Stan has dry wood. I'm not making excuses for burning wet wood.
But I am telling you that dry wood will darken the glass on a very low/ smoke free burn in some stoves.
The first versions of air wash systems were often not very successful, regardless of how dry the wood was. I'd wager even Woodstock had a learning curve with them. I know VC did.
David
I believe they lied about the 4.3 too...lol
It must include the space the cat take up also.
David
