Hi all,
The glass of the door of my PE Summit has raged war on creosote. This year, the creosote is winning the battle.
Unlike other years, the creosote has built up to a bubbly crusty mess, whereas, before, it was mostly just discoloration that could be easily removed with a piece of newspaper.
Nowadays, the buildup is so thick, I can't even see through the glass.
What would you suggest as a removal strategy? I tried hot fires, which usually work. Newspaper didn't. I thought about using a razor blade, similar to removing paint from glass. My main priority, obviously, is to prevent the glass from getting scratched.
Any suggestions... Other than..."get better wood" or "burn hotter"?
Any thoughts or discussions are welcome!
Hope you guys have had a good burn season!
