Finally got a contract for my solar array. Getting 28 panel 405 REC Alpha panels paired with enphase IQ 8 micro inverters
That system should work well for you. Congratulations!Finally got a contract for my solar array. Getting 28 panel 405 REC Alpha panels paired with enphase IQ 8 micro inverters
What's the outlay? Don't ignore historic level inflation, in your calculations. The $10k you spend today will be worth much more at the end of 9.8 years.So I'm at 2.73 per watt with an estimated 9.8 year pay back
Electric rates are going to have to go up to provide infrastructure for charging electric vehicles. Assume 1.4 cents per KWH according to the link but I think it will be more like 2-3. Add inflation and factor in natural gas prices Rates going up by 20-30% in the next 5 years is not out of the question.What's the outlay? Don't ignore historic level inflation, in your calculations. The $10k you spend today will be worth much more at the end of 9.8 years.
With current tech those extra charge cycles on my vehicle are a tough sell for me. my family tends to run all our vehicles past 150k miles. i think it probably makes more sense for a 10-30 kWh battery at home even more if you have solar. Utility level mass storage is more likely/ already in service.Considering that most EVs used for commute transportation will be parked 8 hrs while one is at work, they also offer the potential for a large daytime reserve capacity for the grid.
many people won’t be bothered to charge off peak or schedule a charge by departure time. Come home plug in, crank AC, cook dinner. Cant say this a a good source but….. https://finance.yahoo.com/news/ev-adoption-behavioral-changes-101718236.htmlWhy do you assume EV's will create a large increase in required infrastructure. If managed properly, most EV charging demand will occur overnight, when present usage is at a minima, thus minimizing any impact on peak daytime demand. It has potential to solve a lot of issues with throttling supply, and allow for better utilization of long-time-constant options (eg. our local nuke plant), than ever before.
