good or bad insulation use?
labrador
196
upstate New York
road runner
Will the insulation 6" fiberglass create more heat.than losing it to the side walls of the fireplace? The other photo is of the flue closed off by a block off plate which is above the fiberglass. The white is stove insulation on the flex pipe side.
  • [Hearth.com] good or bad insulation use?
Here is the second photo. (Thanks,Jake) :)
Only one photo made it. Is this a double-sided fireplace? If yes, I don't think I would insulate at all. A damper block-off plate should be sufficient.
BeGreen, It is a double sided fireplace, with lots of room. I think the second photo did come through. :roll:
Now I see it... But I don't see any need for the insulation. There isn't a mass of exterior masonry on the backside of the insert.
+1. Any brick that warms up is just going to release heat to the rooms anyway. I wouldn't have insulation stuffed right up against the unit regardless.
Thanks for the advice. I will remove the insulation on the sides of the stove. It has to heat more of the brick surrounding the fireplace, and through it into the house.
You might want to put a nice expanded or stamped metal grillework on the backside for a cleaner look. That will let heat from the back of the insert into the living space.
