Good stove thermometer?
We have a couple of those. They seem to work fine for us. I have found the needle is even a bit movable so it can be "calibrated" if your neurotic enough to go through the trouble.
I have two, one made by rutland and one by condor and they are 100-150 off of each other so now I guess I will buy an IR tester to see which one is correct.
Oh, I have Rutlands and I have Condars, and no, they don't all read the same...but what difference does 50°F or even 100°F make when you're talking about a woodstove? Not a hell of a lot, I think. This coming from an obsessive-compulsive Mechanical Engineer. It ain't rocket science. %-P Rick
I have a Rutland and a IR temp gun. The Rutland doesn't get lost as it stays stuck to the stove. The IR is more accurate and the Rutland is in the ballpark. But as Fossil said, 50F difference is not a big deal. The temp across the top of the stove varies that much or more. You get to know your stove and if the magnetic thermometer is always in the same place, it is a good indicator of what your stove is doing.
Well mine are 150 degrees apart at times and I dont like it.
When I compared my Rutlands with my Condars the Rutlands were always 75-100 higher once they got up in the 500 range. I like the Condars better.
Bought a Condar Inferno last year. It agrees with a surface thermocouple probe to within 10-ish degrees at 400, 500, and 600. Oddly enough, I bought it to replace a 23 year old VC branded magnetic stovetop thermometer, figuring that after all that time it has to be reading incorrectly. No so. The old VC agrees well across the range with the new Condar.
Is your old thermometer by SandHill with a white face behind glass? If so, we have the same. Ours is approaching it's 30th birthday and is still pretty darn accurate according to the IR thermometer. Wish this model was still available. I'd recommend it in a heartbeat.
BeGreen said:
Unfortunately, not even remotely similar.
I guessed as much, bummer. It seems like the condar might be the pick of the litter.
It does have a white face, but there's no glass. It's constructed almost identically to the Condar.
Condar stove thermometer . . . found that the temp was very close to what my IR gun said the temp was. I also have a Condar probe thermometer for the flue . . . although I can't say how accurate it is.
According to Condar, that series was made by them. I must have got one of the earlier batch. If I had to get another, it would probably be the TelTru. They are expensive, but should last decades.
Green Energy: You said, ".............The IR is more accurate." I wonder........how do you know that? (serious question). What did you use to prove, or perhaps better said, HOW did you prove out the IR? I have a Rutland, on the stove, and a Condar on the flue pipe, and MY "IR" (a.k.a. Laser Temp Thermometer), didn't agree with either one.
Taking the Condar out of the equation, since that's not a fair comparison, because the Condar is reading the gas temp inside a double-wall flue pipe, and my IR is reading the outside temp of the external pipe, .........that leaves the IR's reading of a location next to the Rutland, and thru the glass.
I've been wondering how I can determine which (the IR or the Rutland) is closer to the more accurate temp.. How did YOU prove the IR's readings?
In answer to the OP, I'd say that Condar and Rutland have been in business for a while now, and they make reliable thermometers for establishing trends with your particular burning style and equipment. I've given up trying to compare MY temp readings to others, (although I STILL would like to know the ACCURATE temps of my burns), since all systems and styles of burning, and woods used, are somewhat different.
Even though I have a Rutland Thermometer on my stove, I've just ordered THIS Condar "Chimgard" Thermometer. I'll put this one and the Rutland side-by-side, and we'll see if they agree. Maybe THAT'S a way to do a comparison?!
-Soupy1957
  • Good stove thermometer?
Thanks for the reminder. I need to shop for this. I need two? To put where?
Condar is right down the mountain from me. I wonder if they ever have a factory sale :p
-Soupy1957
IR Laser Thermometer I have has a rated accuracy of +/- 3.5 F according to the spec sheet:
http://support.fluke.com/raytek-sales/download/asset/mt_bro_1-1101_revf.pdf
The markings on my Rutland are at 25 F intervals. So if the Rutland is more accurate, which I doubt, the read out has the limitation that you can not read it as accurately as the IR laser gun.
As I said in my original post on this thread, the temperatures vary by 50 to 75 F or more across the top of my stove when its cruising. So I am not concerned about 25 or 50 F. I keep track of the temp because I am that kind of guy, but once the temps are above 500 F, I am turning down the air based on maintaining the secondaries. I can usually get the primary air down to less than a quarter, or an eighth, depending on how I have built the fire and the type of wood.
GE
For a modern accurate thermometer, TelTru makes a nice unit. Tel-Tru DM-014-750
https://www.hearth.com/econtent/index.php/forums/viewthread/21244/#231799
I just bought this one....it arrived today. I'll have to wait until November to give any feedback on its performance.
It's a solid little unit though, with glass face and two strong heavy magnets.
My old thermometer was a freebie that came with the stove. I'd already fixed the broken inidicator arrow on it once.
I figured a one-time investment in a quality thermometer was worthwhile. It should help me avoid conditions that'll damage my catalyst and other stove parts (just replaced the 20 odd year old cast iron throat hood that was slumped and eroding on the edge where it tends to glow red hot inside the firebox).
-Soupy1957
The condor you show is a stove pipe thermometer and not made for the stove top. It will not show the true reading.
BLIMP said:
test by placing in 300*f oven 4awhile & remember the difference?
I thought someone posted a while back that placing them in an oven did not work very well for a test.
so the one that I just got with my Woodstock Keystone looks like the Condor one - any idea of how good this one is - should I buy another
time to test the oven vs the IR gun?
