Got some white mold.
StevenearBoone
3
Lenoir
Discovered some white mold after removing the tarp,it had been stored like this since early spring.
It’s mostly oak.
Can I still burn it or should I let it season for a while more?
I don’t have a moisture meter.
Thanks!
Steve.
  • [Hearth.com] Got some white mold.
  • Love
Reactions: burning VC
I doubt it's near ready. It should have been split. Rounds hold moisture much longer to dry out in the center. I strongly reccommend getting a decent, but inexpensive moisture meter to take the guesswork out.
It depends if it’s dry.
Mold doesn’t grow where water isn’t present. You may need a bit of time for it to dry further.
Reactions: StevenearBoone
Harbor Freight has a meter for $14 or so. Your biggest rounds will probably have the most moisture. Get a round up to room temp for a couple of days, then split it and check in the center of the freshly exposed wood.
Some of those rounds have quite a bit of checking on the ends, but that doesn't mean a lot with Oak, or with unsplit rounds as a rule. I have some rounds of Red Oak from a dead tree that was too close to the house, maybe 2' or so diameter with bark and sapwood fallen off while it was still standing. The rounds have been lying on the ground for a couple of years. There's a lot of checking on the ends. I recently split one open...still 30%, way too wet.
Tarp is OK but only for covering the top. You want air moving through the stack to carry moisture away.
Reactions: all night moe
To test for moisture, the round will need to be brought up to room temp around 70º. Then it will need to be split in half and tested in the middle of the freshly exposed face of wood with the prongs parallel to the grain.
