Grease on OAK slider?
DemonGT
161
Sparta,WI
Been having issues with the slider adjuster for the OAK sticking so i removed it and cleaned it with a wire wheel. Moves a lot better now but to keep it sliding good would i be able to smear a light coat of wheel bearing grease on it?
Reactions: Washed-Up
I've never heard of a slider on the Outside Air Kit.
Its usually on the stove
As far as putting grease on it you really want something flammable like that on the stove. I have never adjusted mine in 9 years i found the sweet spot between the setting i use and leave it
Don’t have an OAK on my Jotul 3cb but do use a dab of high temp anti-seize on the bottom air slider for smoother operation. It’s not a pellet stove but it does get hot and the proper anti-seize will not burn or off gas.
Ok I have no idea what this slider is…anyone have a photo?
Reactions: bogieb
Yes, its on the stove itself.
  • [Hearth.com] Grease on OAK slider?
Ahhhh ok, mine definitely doesn’t have that but this is the first one I’ve seen…is it for draft?
I realize that, I just have not seen this type before…
Reactions: johneh
All stoves have a draft adjustment
Mine don't have a slider. I think there is a draft adjuster on the control board, but that is set during install and I never touch it, nor would know what to do with it. I'm not even sure what it does since there is a flapper in the air intake, so just opens when there is suction created by the exhaust fan.
