Owners of the Green Mountain 40: I am considering installing this stove in an existing fireplace. It checks all the boxes in terms of aesthetics and performance and would be a perfect fit in the firebox *except* for the catalyst bypass handle. Based on my measurements, the handle would contact the masonry when positioned toward the rear of the stove. The exploded parts diagram for the stove appears to show that this handle is attached with a set screw to a rod that turns the baffle. My question is if it's possible to reorient this handle, ie, have it face down or forward instead of backward when engaged. If so, I'm certain the stove will fit. If not I'd either have to position the stove off center of the hearth (not ideal) or shorten the wood portion of the handle (probably doable, but not sure I have the skills to pull it off). Any insight would be much appreciated.
