Greetings,
Happy Sunday everyone. I am a first time poster from Hampden, MA. About 2 years ago, I purchased a 2000 sq ft farmhouse that depended on a glenwood "C" for heat. The stove was overheated badly/consistently and the last owned burned a bunch of trash. I found glass, milk cartons, magazines, plastic, and so much more crap 1/2 burned in the fire box and ash pan. The stove was about 6" from a wall-papered plaster wall and that was baked too. To boot, he had some raging chimney fires over the years. So... out with the glenwood, in with lp forced air, and a new wood stove. A chimney sweep and an expensive bill later, I had the chimney cleaned up, repaired, and the thimble replaced.
The chimney sweep only installed a 6" ID thimble. It is very heavy gauge galvi-steel, but it isn't exactly 6". It was pushed out of shape, loosing/gaining a 1/8" or so on the vertical/horizontal diameters. The thimble has good clearance to the studs and has a cement collar around it, coming to the surface of the my fire-rated cement board backer. Slate tile is laid over the backer, forming a little less than an inch of backing. I would like to use 6" double wall pipe to reduce my clearances, and there the problem presents itself. The thimble is 6" ID and the double wall pipe is 6" ID. I won't be able to fish the pipe through the thimble (which is 16" in length). So... without removing the thimble, does anybody have any ideas on how I can achieve a safe connection without busting in a new 8" thimble?
Thanks for the help!
~Joe
~Joe
