I'm looking for some help choosing a stove and figuring out where to put it.
Some background...
The wife and I just moved into a new home - 1680 sq feet of living space. Finished room in lower level. Main level has open concept living / kitchen area, hallway which leads to bathroom and 3 bedrooms. Master bedroom is at the end furthest away from living area. Propane, forced air heat. The propane is getting very expensive.
Regarding placement: Ideally, we would have the stove on upper level in the living area. But the thermostat is on that level and the geniuses who installed the heating system only put in that one zone. So the room on the lower level gets 4-5 degrees colder. The lower level room does have heat but it only comes on when thermostat upstairs calls it.
So if I put the stove on the upper level, I'll have the same problem because the heat won't sink into the basement (right?)-- and it may be even worse because the heat will never turn on due to the thermostat reading always staying high.
Should I just put the stove in the basement and open some registers in the upper level floor? Perhaps the heat will just rise from the basement and up the stair well.
Either way, will the heat make its way down the hall to the last bedroom?
I'm looking at Harman's since they get good reviews and have been around for a while. Probably a P61A or P68. Not sure. Any thoughts are appreciated.
Thanks.
Some background...
Thanks.
