I am putting a new hardwood floor in front of my PE super 27 hearth. I'm wondering if there's a specific floor that won't separate or cup. What are your experiences with hardwood and stoves? Thanks
Is the wood going to be the proper distance from the stove?I am putting a new hardwood floor in front of my PE super 27 hearth. I'm wondering if there's a specific floor that won't separate or cup. What are your experiences with hardwood and stoves? Thanks
Post some pics of the dry rot. Interested.If you decide on a true hardwood over laminate, the denser hardwoods will move less. White oak is very moisture resistant. Red oak is a bit prettier. Hickory will take a beating like no other and is moisture resistant. I'm actually choosing reclaimed hickory for my kitchen. It has chestnut now from the 1920s and dry rot has set in. There are other good choices of hardwood at a significant cost increase. For instance, mahogany. Popular with boat decks and open porches.
If going with engineered flooring, avoid the box stores. Quality will be had at flooring outlets.
www.hearth.com
Can't post pics. Phone won' link to computer or visa versa. I haven't the patience to figure it out. Much easier to say, "screw it," then to destroy the laptop or twist the phone in half from frustration. I'm technology challenged, computer illiterate, and couldn't care less.Post some pics of the dry rot. Interested.
We have the same setup on an oversized corner pad inset in a white oak floor. There is a slight separation of the planks in the middle of winter directly in front of the stove. This is a millimeter or less. The tiny gap goes away as soon as we stop burning. The issue has been mitigated by placing a small hearth rug in front of the hearth pad which is also greatly appreciated by our cat.I have my PE on a corner steel pad on top of my Oak hardwood floor. No problems.
![[Hearth.com] Hardwood in front of stove [Hearth.com] Hardwood in front of stove](https://www.hearth.com/talk/data/attachments/325/325646-6c2d21e816e400bb568ec256b7fd8bef.jpg?hash=LLNErWm3nG)
Your setup looks nice. I also have a window to my left and a wall outlet. Nice when plugging in the hairdryer.We have the same setup on an oversized corner pad inset in a white oak floor. There is a slight separation of the planks in the middle of winter directly in front of the stove. This is a millimeter or less. The tiny gap goes away as soon as we stop burning. The issue has been mitigated by placing a small hearth rug in front of the hearth pad which is also greatly appreciated by our cat.
Ours is too, but 25.5" across the front.Edit: since my steel pad is only about 16” straight across in the front a hearth pad would not work. More like a trapezoid up front.
Our floor went down in 2006. It's fine at least for my lifetime. Wood shrinks and expands seasonally in a house due to humidity variations. It probably does as a tree slightly too in different seasons.I don't think it's good.for.the longevity of the planks (repeated shrinking and expanding can't be good for the mechanical integrity of the wood), but on my time scale (6 yrs) it's not yet deteriorating. Avoiding it from happening is what I would advise, if feasible.
Do you control the humidity in your house to keep the boards from separating?We have the same setup on an oversized corner pad inset in a white oak floor. There is a slight separation of the planks in the middle of winter directly in front of the stove. This is a millimeter or less. The tiny gap goes away as soon as we stop burning. The issue has been mitigated by placing a small hearth rug in front of the hearth pad which is also greatly appreciated by our cat.
