heat seeker
My OAK pulls from the garage. Unheated but we'll above outside temps.
Hope you don't suck in some gas vapors. I think that may be against code - at least my stove manual says not to do such - use outside air only.
Only thing in this world that scares me is my beautiful bride!PTL I'm still even here !! No other explanation. And I didn't fly airplanes in times of war. Those who did I'm sure are double grateful.
Store gas in combustibles cabinet or outside in shed.Hope you don't suck in some gas vapors. I think that may be against code - at least my stove manual says not to do such - use outside air only.
![[Hearth.com] Harman 52i not working properly--low heat, runs dirty, excess ash [Hearth.com] Harman 52i not working properly--low heat, runs dirty, excess ash](https://www.hearth.com/talk/data/attachments/150/150187-f67ca94022d859a2bf234fd70d05019b.jpg?hash=0hi3I0hSha)
![[Hearth.com] Harman 52i not working properly--low heat, runs dirty, excess ash [Hearth.com] Harman 52i not working properly--low heat, runs dirty, excess ash](https://www.hearth.com/talk/data/attachments/150/150189-3818b4d1bdc94262d53207fe97709479.jpg?hash=nn2rjNORAN)
I'm fairly certain that this large (what is it? 1/8"?) mesh in that nearly 3" ID tube isn't causing a restriction.
If that's a restriction then I have no idea how my <2" pipe breaths through this tight-mesh screen:
I even taped off half of my inlet as an experiment based on a post by Mike from ESW and it still barely affected the burn.
Actually as part of this experiment he is undergoing I'd be temped to say just pull the OAK line off at the stove for now.I suspect that in your case there is a short almost direct run between the intake on your stove and outside on your OAK run. I don't believe it it true for the OPs run, I'm not certain but I think the OAK run on the OPs setup has a few bends in it. Further it looks like that mesh has crud on it never a good sign. As oak runs get longer you have to increase the size of the plumbing used. I asked for a picture so we could see the stuff behind the curtain.
It only takes a little bit here and a little more over there to screw up the air flow And in this case the intake is also higher than the vent outlet also not a good thing..
He did not do a draft test.
Eric
I finally got the fake Christmas tree out to the shed, recovered over the chipper while outside. Came in rode my bike in the stationary stand. Went to the piano and rehearsed for Tues Night's service, sat and had tea and did some reading. Now I'm texting my daughter and hanging out here. Oh and I filled the hopper with pellets for the night.Well at least I got to post a couple of things from my TV and the wireless input devices disentangled from the wifi link while waiting.
I suspect that in your case there is a short almost direct run between the intake on your stove and outside on your OAK run. I don't believe it it true for the OPs run, I'm not certain but I think the OAK run on the OPs setup has a few bends in it. Further it looks like that mesh has crud on it never a good sign. As OAK runs get longer you have to increase the size of the plumbing used. I asked for a picture so we could see the stuff behind the curtain.
)![[Hearth.com] Harman 52i not working properly--low heat, runs dirty, excess ash [Hearth.com] Harman 52i not working properly--low heat, runs dirty, excess ash](https://www.hearth.com/talk/data/attachments/150/150222-3ad28d8767c57504708b279d4076fb30.jpg?hash=HBqUVZBuks)
Did you hear about the Higgs-Boson particle that went into the church and said "You can't have mass without me?"".... rehearsed for Tues Night's service.....
Oh boy !Did you hear about the Higgs-Boson particle that went into the church and said "You can't have mass without me?"
Hi Smokey.
A GT500 has a much more powerful air motivator than a pellet stove. Just sayin'. I have a 3" OAK, and the inlet has ¼" screening on it. So far, so good.
Mine has an "S" shape due to running it through the flange of the exhaust thimble, but it is less than 2' long. I have no issue with the possibility of an airflow issue, but the contribution from that loose mesh screen on that large of a diameter is miniscule.
For reference, this 5.5" diameter opening from the filter on my supercharged GT500 passes air across this much tighter mesh at 950 CFM - or greater than 3X the CFM per square inch compared to the one the OP has (I did the math)
Yes but you have a 950 CFM sucker, it is sort of like using a leaf blower to clean a pellet roaster that sucker can move far more junk and air through a lot of twists and turns than the exhaust blower on most stoves.
Which makes even a minor hindrance an issue.
If a stove has issues with long twisting pipe, then that's the issue. Each contribution is like a resistor in series - they add up. Focusing on what can't be more than a 1% contribution (that large mesh screen) can't be all that worthwhile IMO.
I'll take any and all reductions in hindrances to air flow, no matter where I can get them.
Well, good thing my team just won a very stressful game and I am not tired of discussing this yet.![]()
I thought the game was over when the Patriots were running out the clock. I came back and Baltimore had the ball and throwing a hell marry pass. Message to self, "never walk away until the time runs out."
OMG! I was doing a victory dance when Brady kneeled even though I was just explaining to my daughter that 1:39 - 1:15 = 0:14. Lesson: math is never wrong. Lol. Pats nearly gave me a heart attack in that one!
That's what I say about my engine where any inlet pressure drop is a multiplied loss since it's before the supercharger.
Since most stoves are overblown, they have input dampers on them to limit intake air or the combustion blower motor is running on just a fraction of it's maximum setting (4 of 9 on my stove), I assume that any stove that has proven it can run properly over a 24 hour period likely has the restriction after the air inlet to the stove - as I think is usually the case. Am I wrong?![]()
