We have a somewhat drafty living room where the 5 year old insert is in the fireplace. The distribution blower shuts off periodically and we can't seem to get the room as hot as we used to. I have done all the maintenance and cleaning. All original parts still. I have cleaned the ESP probe previously. I want to be able to set the stove so that the distribution blower never shuts off and maxes out the heat to the highest possible extent.
Currently...
Temp: 7/90 degrees
Feed: 5
Igniter: Auto
Mode: Room Temp - High
Thermometer is about 6 feet away from stove and the actual room temp gauged by our central heat thermostat on opposite side of the room is only about 67 degrees when it is 40 outside today. When it is colder outside the room may only get to low 60's. In the past, we have been able to get the room to the low 70's.
I'm trying to think all about this logically, but without having full knowledge of all parts.
The igniter does sometimes seem to lag a bit when lighting in the morning, but I don't think that would cause a problem with the heat output once it gets going. Although the blower operation is intermittent, the blower doesn't seem to make noises like it is going bad, but I'm not sure. My logic is telling me it might be the instructions from the system telling the blower to shut off.
Our budget is tight, so I don't want to spend money on parts unless it is really necessary. I have done a lot with computers and hardware, so I feel I could change almost any parts without paying a dealer. In speaking with our dealer, they told us they would need to take the stove back to their shop if the blower or system board needs replacing...I don't like this answer...do you feel it has to be this way? (I feel like they may be trying to ramp up the labor charges.)
What are the best settings to keep the blower and heat output high?
If I can't get the distribution blower to stay on constantly, what parts would I consider replacing?
Where are the best parts prices/reputable dealer online or to call to order?
Thanks in advance!
			Currently...
Temp: 7/90 degrees
Feed: 5
Igniter: Auto
Thanks in advance!
		![[Hearth.com] Harman Accentra distribution blower shuts off](/talk/data/attachments/146/146333-8ed672223810484cda270efe3534bd77.jpg?hash=uidL2__WZc)
