Harman Advance Help Needed
Fire
67
NYC
My Auger will not spin. I tried moving chain manually and there is alot of resistance and will barely move in either direction. I removed all pellets from the hopper and the slide plate seems to be stuck also. The auger motor sounds like its working. I've tried test mode and room temp as well as stove temp. I check the fines box, it was just about empty, I scraped the burn pot around the auger, no resistance there. I'm Stuck!
While you had the fines cover off did you try to move the slide plate to free it up
I rechecked the fines box and found the slide plate had become dislodged. I can't figure out how that happened. I reassembled and now all is working fine. 10 years with this unit and I'm still learning! Thanks corkman.
Reactions: bogieb
Schweet
Reactions: bogieb
