Harman door gasket
dlavigne7324
273
Hello All
I have a p35i had it installed January 2011 and did a dollar bill test on the door gasket top is tight. bottom dollar bill can be pulled right threw the whole bottom .. Does it need to be replaced ?? Called 3 harman dealers 2 of them said replace the other said no ... So what's your thoughts
Yes, its a easy job. Air going in where it shouldn't reduces your burn pots air. Possibly sooting up the stove and quickly reducing the exchangers ability to conduct heat.
  • [Hearth.com] Harman door gasket
It's probably about that time to replace the rope gaskets. It is inexpensive and I just did it on my used stove. It's an easy little project and the rope kits are cheap. I paid $7 for each of the two I just bought a month ago. Just a little elbow grease.
3/8 or 1/2 inch?
Sam
3/8 or 1/2 inch?
Sam
It's hard to remember which size I used but it was one of those two sizes. I know, useless answer. It should state which size in your manual. I don't have the P43 so I am unsure and size could be model specific. Use the search bar here or check your manual.
I am pretty sure you need 3/8" rope but double check.
The 45s take a 3/8 like the picture I posted in this thread
Thanks, will pick up a 3/8" kit over at East Coast on way home today.
Sam
