... at two tons burned it sure sounds like it needs cleaning. Two tons is my limit on cleaning everything...
Thanks for responding I cleaned everything ran brush down from cap exhaust fan replaced docking gasket was kinda squished thought that was it it seemed ok after that but know blinking again was told it was a vacume issue tested vacume switch with meter seems ok. I sanded the esp when cleaning do you think that could of damaged it but that's no listed under trouble shooting for six blinks was gonna do door gasket but looks ok??? 250 lb paper weightWell, you say you cleaned it but ya know what, at two tons burned it sure sounds like it needs cleaning. Two tons is my limit on cleaning everything, including brushing the vertical run out my chimney, horizontal run from front of the stove to the T ( P61 here on a hearth, so I have a T). Blower fins, ESP, Fines box, hatch under the burn pot. Burn pot holes. Check gaskets, make sure a pellet didn't get crunched into the cover gasket of the hopper. tap on the burn pot to shake down any ash built up on the igniter, as always that's just a routine thing on any Harman.
If you've owned the 35i for a while I'm sure you have seen the video on cleaning and performed all these tasks, but just in case, 7 minute video on a 35i: https://search.yahoo.com/yhs/search...n+video&ei=UTF-8&hspart=mozilla&hsimp=yhs-001
What exactly have you cleaned ?
There are inner chambers to clean, behind the combustion blower to clean etc. All done ?Thanks for responding I cleaned everything ran brush down from cap exhaust fan replaced docking gasket was kinda squished thought that was it it seemed ok after that but know blinking again was told it was a vacume issue tested vacume switch with meter seems ok. I sanded the esp when cleaning do you think that could of damaged it but that's no listed under trouble shooting for six blinks was gonna do door gasket but looks ok??? 250 lb paper weight
Yes I removed the back cover took out ash bin cleaned the tunnel up to combustion blower I ran it before I cleaned and was fine problem started after cleaning theirs a bolt on the left side that they test for vacume do you know anything about thatThere are inner chambers to clean, behind the combustion blower to clean etc. All done ?
At the bottom of those plates do they sit on the outside or go on the inside of the bottom openings have you ever removed these bottom plates that are bolted in???Check the 2 triangle shaped side plates. If one of them is not seated properly it will cause issues.
Yes, that is designed for use with a manometer to fine tune combustion blower speed.Yes I removed the back cover took out ash bin cleaned the tunnel up to combustion blower I ran it before I cleaned and was fine problem started after cleaning theirs a bolt on the left side that they test for vacume do you know anything about that
