Good Morning all, or afternoon for most of you. My wife and I recently purchase a new P52i. It is installed in an existing zero clearance opening. I have been noticing some noises out of this new stove that we never heard out of our old Breckwell P23i. The first is when the stove is coming up to temp it frequently makes popping and cracking noises. I'm assuming these are coming from the metal expanding and contracting as this stove gets very hot in comparison to our old one. The noises are not from pellets being split by the trap door. We have that too, but these are more metallic sounding. Also does it when the stove reaches temp and starts cycling down. Probably normal but didn't expect it from a higher end product. The second also happens when the stove is coming up to temp and the distribution fan kicks on. It is sort of a humming, vibration noise. Maybe buzzing would be a more accurate word. It seems to only last for a little bit then goes away. This one doesn't sound normal to me. The stove is only a couple weeks old. I would hope that on a premium product like this everything would be pretty tight and balanced as to avoid vibrations. It makes me wonder if it's something to do with the install. Could it be the jamming rods in the mounting frame vibrating on the metal box of the zero clearance enclosure. I don't believe the installer even put any mason screws into the mounting holes on the bottom of the mounting frame, so maybe I need to anchor that down to the hearth/brick. Any thoughts. Happy Friday to all.
