I have a early model P68. My model has the 5 air feeder holes located at the bottom of the burn pot. The burn pot is original. I see that the auger on my P68 has the tip burnt off. Question......are the 5 holes located at the bottom of the burn pot ( and very close to the auger tip) causing the flame to burn the auger? Is this the reason newer P68 burn pots no longer have these 5 holes? I also have alot of carbon built up at the bottom of the burn pot. If I install the newest style burnpot (without the lowest 5 holes), will this solve the burnt auger and carbon. Hopefully somebody out there experienced the same thing i did and can answer this. Thanks in advance
