I recently had a Harman p68 pellet stove installed.  I noticed a vibrating noise when ever the distribution fan was at half to full speed.  I removed right rear cover and noticed if I touched the distribution fan body it would stop.  I would walk away and within a couple minutes the noise was back. I checked that everything was tight did not see where anything was rubbing or anything like that.  This went on for a week or two trying different things to fix it.  I finally did.  I know this is a Gerry rig, but it did work. I measured the distance between the hearth and the bottom of the fan body, cut piece of 2x4 and wedged it between the hearth and fan body with just enough pressure to keep it there and that's it, noise has stop 100%.
