So I bought a used Harman pc45 pellet stove. I cannot get the distribution blower to turn on. Stove temp maxed out, every possible setting combinations have been tried. I've read the other threads on similar issues and have replaced esp probe black wire, room temp thermostat wire and now today a brand new control board. All dip switch settings are correct on the board and same problem switch 5 is off which is correct for the black wire esp which I have and is brand new. Eventually the distribution blower turns on I'm assuming to cool the stove however when you adjust the fan speed L H it doesn't do anything. Also when I turn the auger feed rate all the way up it doesn't feed any more than when it's on 2. No blinking status codes. I'm at a loss. Any help would be appreciated. Everything works in test mode.
