I have a Harman P68 stove. Mostly works fine except it won’t maintain a 68 degree room temperature. If I set the dial just above 70 it will heat the room up to around 77 but if I turn the knob just below 70, the stove will shut down and then just allow the temperature to drop completely. I turned the oil furnace thermostat down to 63 and the room will go to 63 while the pellet stove does nothing. It will start immediately if I try to heat the room to the high 70s but below that just shuts down. The stove is at least 15 years old.
