This is me second year I am burning with the Tl 300. My first year was an experience to say. The problem I had were that it was my first year burning wood and did not really know alot until I got on this site and people steered me in the right direction. Second my wood was only seasoned for six/seven months. I have all good hardwood that needs that year or better.
Now my second season I love the stove. Easy to burn 24/7 and heats my whole home. I live in a rancher and have my stove in the finished basement/wreck room. I also believed I had a depressurization problem due to the location of the stove. However i intalled an O.A.K and seems to work well. I have not had any problems this year getting the stove engaged into after burn. However I noticed this stove does burn differently than some other down draft stoves. when engaged and burning as should you do not have any flames throughout the firebox. You get secondary swirls of flames occasionally, but most is going through the back into the afterburn system. I noticed more secondary burns about midway through the burn cycle. Importotantly to see if the stove is operatimg as should I check the chimney. No smoke = afterburn engaged. At times though when I check right at shutdown little somke is coming from chimney after everything settles in no smoke.
Keys to burning this stove..
1. DRY WOOD DRY WOOD
2. Its a big stove need to bring it up to temp on initial start at least 550 600 degrees before shutdown.
3. Good bed of coals
Now I have been averaging 10 -12 hour burn time.......
