I am getting ready to do an install on a Harmon Accentra fireplace insert, but it's going into a fireplace opening that I will create, using a Harmon zero clearance enclosure with all of their approved flue components. I am a person that believes in following all codes, and do my reading up front, BEFORE I start. I choose to do my own installations whenever I can because 1) I am capable, and 2) I have found that when properly done by me, the results are usually better and up to my standards, (I am just very fussy about workmanship). When I have everything complete with tiles surrounding the insert, the hearth, and the mantle, it should look like an insert that was placed into an existing fireplace. Because of the limited specs from Harmon, they don't go into much detail relative to the clearances required other than to say that the clearance is 0" from combustibles on the sides, and 12" between the top of the insert and combustibles above, like the mantle. I assume they mean the top of the insert itself (where the door opens to allow the dumping of pellets), and not the top of the cast iron surround piece above the insert. I will ask the dealer but was curious to see what others might have to say. Any other tips would also be most appreciated.
Ranckie
Ranckie
