Howdy all. I searched the forums here, but didn't find this problem posted before. If more info is needed, please let me know.
Running my Advance on Stove temp, set to Automatic, with the feed rate on 4 and the Temp knob set about 75, this stove is shutting off for a few seconds, then turns back on.
First, the distrabution motor shuts off, then a few seconds later, I hear the combustion motor shut off for about 5 seconds, then everything kicks back in. The status light is giving me three blinks, but has been since last season. If I unplug the unit, the status light stays off for a while, then blinks again.
I have only had smoke in the hopper once, and it never happened again. I have the air intake sucking air from the outside, but did remove just today to see if that had anything to do with it. It didn't.
I ran a seperate 20 amp outlet on it's own breaker, and have no problem with power. It doesn't matter what type of pellet I use. I have moved my temp sensor to the back, and both sides of the unit with no results. I haven't called the dealer yet, because I would prefer to fix it myself.
