Hello! I'm the proud soon-to-be owner of a Vermont Castings DutchWest non-cat stove. It calls for an R-value of 1.04 for the floor protection and needs a 48x48 hearth pad. Now, I live in a mobile home, so I have sort of unique hearth building problems...
We're replacing the floor in the kitchen, where the stove is going to go. There was some water damage to the subfloor (which is made of PARTICLE BOARD of all things!) so we're just ripping it up and starting over. I don't actually have decking under my floors- It's just 2x8s (in some cases it's 2x4s nailed together...) for beams. We're going to be replacing the subfloor with 7/8" OSB sheathing and then laminate flooring on top of that.
I was thinking I would put Micore or Fiberfrax on the subfloor, and then tile on top of that. It just seems like the easiest thing to do and the thing that will make it most flush with the floor. I've found sales offices for both of those, so I'm hopeful that I can find a 48x48 piece of it somewhere!
My questions are:
1. What kind of tile is suitable for going on top of the fiberboard? What kind of substrate is best to use? Will the OSB - fiberboard - tile be enough? The fiberboard has an R-value of 1.1, but it's going on top of OSB on top of wooden beams, so would a third layer be advised? Perhaps working some kind of spacing between the fiberboard and tile?
Alternatively, can I install the fibrerboard direcly to the beams, without a subfloor? Is it too brittle for that? Could I use a thinner subfloor- say, 1/4" plywood?
2. Since this is probably going to rise up over the floor a little bit (the underlayment for the laminate is only like 3mm and the laminate itself is 6mm), is there anything I need to protect the edges or pretty them up at all? I'm a carpenter's daughter, I've never done tile before. =P
3. This is going to go in a corner. I assume the 48x48 pad will be enough to ensure it has adequate clearances from the walls? I'm getting every possible kind of heat shield to reduce the clearances- the space from either side of the stove to the wall needs to be 12".
4. I was thinking about getting some woven wool Navajo rugs on either side to protect the laminate from stray sparks (I'm installing the laminate myself, and damned if I'm getting to get any scorch marks!) Good or bad idea?
5. Will the laminate be damaged in any way by the wood stove? I know that low humidity can damage laminate, and it's pretty dry here in Utah during the winter anyway, but that can be overcome with a humidifier. What about the heat itself warping the wood?
Thanks for any help you can give me!
~Rose
My questions are:
~Rose
