- Sep 22, 2013
- 15
Hi everybody,
I'll be receiving my Quadrafire Santa Fe stove next weekend and I could use some help interpreting the clearances required to the walls and the size of the hearth needed.
My goal was to place it in a corner of the room facing out. The manual says there needs to be 2" of clearance to the rear corners of the stove from the walls. This would be nice because it wouldn't need to extend out into the room very far. But if you look at the hearth specs in the same manual it says it needs 6" on the sides and front, and 2" in the back. This would not allow me to place the stove as close as 2" to the walls for the rear corners...instead it would be 6"....am I reading this correctly?
here is the online manual for this stove so you can see what I'm reading: (broken link removed to http://hearthnhome.com/downloads/installManuals/7050_128.pdf)
Thanks in advance for the help!
-DB
-DB
I read it as 6" till you get to the back corners.....but now I'm wondering if that was a mistake...
