Hearth.com Challenge: Help design the Ultimate Humidifier
Chris_Up_North
44
Canton, ME
Like many wood burners on here, I don't have enough humidity. I've tried a lot of different humidifiers and none seem to really fit the bill. My latest return is the pricy Venta airwasher and humidifier, which I found to be quite useless, despite feeding it water with a TDS of 12 ppm, pH 7.1 and varying the water and room temperature.
So help me to design a proper humidifier and I will incorporate all the best suggestions, build it and test it before the end of the burning season. I will document it and post all results up here. I monitor humidity with an old-school analog lab-grade dial hygrometer that is extremely accurate.
So here's what the humidifier will have to do:
- Raise the humidity from an average 12% to an average 40%
- Be silent or nearly silent. I feel the thermoelectric fan (EcoFan) on the stove is noisy.
- Not pose a mold issue. There can never be anything growing in the water reservoir, if there is one*
- Low power consumption (this should be easy)
*This could mean a reservoir with ozone injection or other natural solution to biological contaminants
Right now, the leading idea in my head involves using a heavy-duty 1.7 MHz ultrasonic element that can theoretically atomize 50 gal/day if need be. Thinking of using a snap switch thermostat located on the back of the stove and when it hits 200F, it will close the circuit of the unit and funnel large quantities of highly humidified air over the top of the EcoFan, which should serve to make it perform more efficiently thanks to the temp drop and the nature of thermoelectric/Peltier modules. There will be a humidistat calibrated to my hygrometer wired in series as well. But this is just an idea and I know there are lots of Hearth'ers out there with decades of combined experience for keeping their homes properly humidified.
Thank you for your input!
In conclusion, here is a short video of my outdoor, 12' solar-powered, remote control Christmas Tree. It came to life when I felled a massive 80' maple on my property. When it came down, it clipped the top of a 40' pine and ripped it off. Dragged it up to the yard, dug a hole and "planted" it. The rest spiraled out of control from spare parts I had lying around. Draws 1.8 amps at 12 VDC.
Depending on the temperature you may not want it a 40%, humidity level goes down with the temps. so you dont have frosted windows.
Fairly happy with my plain jane essicks.
Love the tree by the way.
ultrasonics are the way to go to get the water in the air. BUT you need water with low TDS, or a RO filter (what i use). wouldnt want it too near the stove, the water droplets will lead to rust on unexposed surfaces (i expiranced this). I have a cheap one from lowes, like it a lot. I would just like a slightly bigger fan to push the moisture a bit harder out of the humidifier.
Get one of these and be done with the problem. Installs into you existing ductwork.
[Hearth.com] Hearth.com Challenge: Help design the Ultimate Humidifier
Airsealing is the ultimate humidifier. Vapor from the shower and cooking is all you will need.
My house is as air tight as they get and I still needed a humidifier in a bad way. Maybe if you had 10 at home taking showers and cooking all the time...but in most cases you need a means to add humidity.
An OAK will also help with indoor humidity.
2700 sq.ft. on two storeys, plus full basement, 18 year old construction. 2 adults, 3 kids. No humidifier needed here.
The ultimate humidifier is the Pacific NW winter. It's 88% outside and 50% inside with the fire going.
I run a large Holmes humidifier. I picked it up on clearance one year after the heating season.
http://www.amazon.com/Holmes-HM3500...difier/dp/B00067TS3M/ref=cm_cr_pr_product_top
I fill it every week and a half or so. The airsealing I did makes a real big difference on how often I fill it up. I need to do a bit more air sealing. Once consequence of all my air sealing is I'm seeing condensation on the windows that I didn't before. I need to turn the humidifier down.
Also in the winter time with the stove running we refrain from running the bathroom fan while showering to keep that moisture in the house.
I like your premise though of a better mousetrap
