Hi, I’m looking for suggestions opinions from members on this forum.
I’m going to build a stone veneer enclosure for the Harman p35i insert from the floor to the ceiling. I have a few challenges along the way, currently the space where the insert/enclosure will go is hardwood floors so to build the hearth I was originally going to just put two ½ cement boards on top of the hardwood and use thinset/screws, after going research I came to the conclusion that this will not work. Some sites suggest putting down plywood over the hardwood floors and placing the cement board over that, which I’m not sure its going to be any better.
Which leads me to the following idea, I’m going to raise the hearth off the hardwood floor using 2x4’s, basically making a box out of that and installing my plywood/osb and then the cement board. My question is, will this help eliminate the shifting that otherwise would occur with the cement board right over the hardwood floor? Is this a safe reliable method to accomplish the hearth over a hardwood floor without cutting the floor out?
The other issue is when I fame using 2x4 should I lay down some plywood and build the framing over that or can I nail the 2x4 framing board directly to the hardwood floors? Mind you I will be fastening the framing to the wall studs and ceiling joists and hopefully the floor joist going through the hardwood floors.
I really don’t want to make more work for me by cutting out the floors and I’m thinking elevating the hearth might save me work although im not sure if I can nail the frame directly on the floor itself.
Any suggestions is greatly appreciated.
p
p
