Hearthstone Clydesdale air entry points.
woodmiser
390
Garnet Valley, PA
I am wondering if anybody here knows anything about the Clydesdale with respect to exactly where it gets it's intake air from. I'm not looking for I thinks and maybe's. The reason is I want more control over the low burn Right now it's way too easy to go hot and th eonly way to shut it down is to open the door. I have a 6" insulated 15 foot liner. Draft is excellent and I have really dry wood. Suggestions on controlling are fine but I really want to know how this stove is designed... where exactly does it get it's air from even when the damper is shut completely?
Thanks all.
Email Hearthstone. I wanted to know the same thing about the Mansfield and they promptly sent me this...
Shawn
  • [Hearth.com] Hearthstone Clydesdale air entry points.
Thanks... will do.
last year our clydesdale seemed easier to control then this year. it's probably because this year i'm using more seasoned wood but maybe the gasket is getting old and not sealing as well....need to do the dollar bill test.
I loaded it up this morning at ~300 deg, pushed the draft all the way in and turned the fan all the way up. about an hr later the temp was up to ~500.
I talked to Hearthstone. They didn't help a whole lot but did say there are entry points for the secondary air.
I started burning some of my not so fully seasoned oak, mixed with my super dry mixed hardwoods and found that I have a lot more control now.
I think my problem was way too dry wood.
Miser, unless you are using kiln dried lumber, chances are your wood isn't too dry. I liked the idea of doing the dollar bill test, it sounds like you may have a small leak somewhere.
My wood has been sitting in a pole barn garage for years. It's really dry. I'll do a door gasket check too.
I have a clydesdale - it's the older model (2007) - and I don't worry at all about 500 degree temps. Just my two cents, but I think it runs best when the peak temps are around 550.
It's the 800 plus spikes I worry about. I just added a digital controller I put together from some mail order stuff. I dropped the thermocouple down the hole where the draft port screw is right in the center on top. Perfect spot. I'll just put a spacer in there next to it for the grill support. Not that it's even needed.
