I have added this topic because I am a new owner of this stove, and for the first season I seem to be having an unusual amount of trouble. I would love to hear about what a typical burn cycle is for this stove from an experienced satisfied user. Please let us know about startup, overnight burns, and coaling cleanout frequency. I have the following problems:
1) Cannot open a door without smoke spillage, no matter how long it takes (I should note that my stove uses the TOP exhaust, not rear) The front door is completely impossible to open without smoke coming out so I normally load from the side. I still get a good dose of smoke into the house -
2) Excessive coaling when set for an overnight burn during a moderate evening say, 20 to 30 degrees. During these temperatures I have to spend 5 or 6 hours trying to get the remaining coal pile to reduce before I clean out the stove. This is an every day process, or the pile gets too big.
3) On moderate evenings (again 20-30 degrees) I cannot reduce the heat output enough when it is fully loaded, even with the air control closed all the way. This occurs once the wood starts its "cook off" gas phase, and tapers off when the gasses are done burning.
4) I cannot obtain an overnight burn without reloading on a cold evening (single digits or lower), but I attribute this to the smaller size of the wood I am using.
My chimney is about 25 feet high with a single 45 degree section, the 45 degree section is about 3 and 1/2 feet long. Everything else is straight vertical.
I am using the top down startup technique and have no trouble getting a good fire going now.
My wood is only 16" size, because I had to buy from the local market since this is the first year in our new house. It is mixed hardwoods like hard and soft maple, ash, and some cherry. I am uncertain of the dryness, some pieces will sizzle but not many.
My stove has an external air feed, because the house is very tight.
I don't mind tending the fire and cutting wood, I have enjoyed a Quadrafire fireplace insert in my old house, and I did not have these problems with the exception of coaling - but the Quad would go 3 days before I had to shovel it out.
Thats the story, this is a great site and I hope to learn enough from all the experienced folks to get through some of these problems.
Thanks
Thanks
Eureka !! The secret is SMALL WOOD :lol: Last night at 11:00pm I loaded it up to the gunwales with 2 to 3 inch splits, what I used to call "kitchen wood". I waited until the pile lit off, reduced the air slowly all the way to zero, and watched the blue flames run the temperature up around 500+ degrees. I slept too soundly and did not restock the stove at night - but in the morning poked the bed, added some "kitchen wood" and away it went - so it looks like I got at least a 7 hour high output burn. This stove likes the small stuff. I will be checking my moisture as soon as I get the meter also. With wood split this fine it should dry very well. I am not kidding; I filled with stuff that was just a little bigger than kindling with perhaps a couple 3 or 4 inch pieces but nothing bigger. What a difference in the burn.
