Hearthstone Phoenix 8611/8612 Baffle Support ?
ADK83
8
Adirondacks
Hello. A while back, I made the stupid mistake of disassembling my Phoenix 8611/8612 without taking pictures. I would appreciate it if anyone can tell me how the “23 Baffle Support” part is supposed to be aligned in correlation to the “36 Secondary Air Manifold." Any help would be truly appreciated.
  • [Hearth.com] Hearthstone Phoenix 8611/8612   Baffle Support ?
Years ago @countybrown posted good images of the assembly, but they were lost in the upgrade. Do you have the parts diagram?
You are not the first to have this dilemma. It's going to take some digging, but this came up for a different Hearthstone in the past. I don't know if they will help with the Phoenix but perhaps they will have a helpful clue.
Castleton baffle instructions
Thanks begreen for taking the time to dig up some helpful info for me. I’ll upload some images when I get it aligned correctly. Merry Christmas
Hello ADK83:,
I am a Home Remodeling Contractor in CT, as well as a certified fireplace/woodstove installer.
I just came across your question on baffle support for Phoenix 8612.
Hopefully you have already
[Hearth.com] Hearthstone Phoenix 8611/8612   Baffle Support ? [Hearth.com] Hearthstone Phoenix 8611/8612   Baffle Support ? [Hearth.com] Hearthstone Phoenix 8611/8612   Baffle Support ?
found the proper position, if not..
The proper position is to have the short 90* go behind the front tube and the fire bricks set on the baffle support.
This also helps keep the bricks off the tubes.
Hope this helps
