Hearthstone Tribute door catch & latch
chickendude
2
chickenman1
Good morning everyone.
New to the site and forums.
I have a 2011 Tribute (model 8040). About a month or two ago, just into the heating season, I noticed the door wasn't staying closed properly. My first thought, and easiest solution, was to replace the gasket. It was about 5-6 (or more) years old. No problem with that. But the door still wasn't latching very well. I determined with a flashlight and magnifying glass that the "catch" on the cast iron door frame had partially broken off. I contacted my dealer and they offered to order a new frame but it runs $250-300. Way too much for me living on social security. My online searches were fruitless except that I found out that Hearthstone has updated the new frame. It is still cast iron but the catch is now steel since the old catches were prone to break. I took my frame to a local custom welding shop (they can weld ANYTHING) and they fixed it while I waited for $100. But the welder said the cast iron design was poor. He could see why it would easily break.
I contacted Hearthstone tech and asked them about this. It seems to me that this is a design and safety issue. If a log rolled against the door and knocked it open while I was away or asleep there could have been a fire. Personally, I think there should be a recall and replacement. But Hearthstone says no. The new frame "....is an improvement..." and "...any modification I did voided any warranty...." Again, personally, I think my "modification" was actually a repair. Hearthstone more or less quit communicating after that.
As it is now, the repair is working. I also adjusted the latch/handle assembly. The door is sealing and working very well.
Has anyone in this forum experienced this? If so, what did you do?
Thanks!
30WCF
531
North Carolina
Is having them send you the new steel latch an option, or did they redesign the whole system?
Teresaac
3
Ohio
Thanks!
I have the same problem.. Company does not want to fix it...
