Hi Everyone,
I'm relatively new to wood burning and installed a wood stove insert about a year ago. I have a standard raised ranch, where the stove is in the lower level, in the fireplace. The stove works well but the heat is somewhat hard to cycle through the house, even with a blower and heat 'finding its way' around corners and up the raised ranch stairs etc. What I'd like to know is if anyone has cut floor registers in their floor, to help circulate the air. If I were to cut the floor and insert the registers, the heat should go directly into the main living area of the house, since that is directly above where the stove is located. Is it just a case of cutting the vents, buying the 14 inch register and letting heat rise and circulate through the house? The floors are finished and in good condition, so I'd want to do it right and wondering how many to add, and if it's effective etc.
Thanks for your reply!
![[Hearth.com] Heat movement with Registers [Hearth.com] Heat movement with Registers](https://www.hearth.com/talk/data/attachments/183/183515-13ee88d50a0b014eaa346a12d6f93071.jpg?hash=4lR-a_FMlX)
