Does anyone know the difference in heat transfer between oxygen barrier pex and copper?
Can you make a heat exchanger out of oxygen barrier pex instead of copper? It would be a heck of a lot cheaper if the heat transfer is similar to copper.
Andrew
Andrew
(Sorry, I had to get that in somewhere!), but since this forum focuses on DIY approaches, I would suggest tying the PEX and 1" copper together. It might be slightly tricky to balance the flow between the two since they should be in parallel but since you already have all this in place, it should work well.
