Heatilator Model EC42 new & quieter fans, looking for input and ideas
Johndoggie
3
Escondido, CA
Greetings. Moved in to a new to us home with a EC42 fireplace that has the 2 fans for moving the heat out of the unit and into the room. The unit is from the late 90's. The fans are really noisy. It's not the fans themselves it is the design. I installed a 5amp rated rheostat to turn them down in hopes of an improvement, but not much help really. I see there are some muffin fans such as the AC Infinity that will move 100+cfm with only 35db or so. Looking for input as to what others have done. By the look of where the fans sit I could actually install more than the 2. I am coming from a home that we had wood stove so I reckon I'm spoiled as to the heat output. Thanks in advance for any input, John
I found some muffin fans that are rack mounted 3 or 4 in a row and I may see if they will fit. Around 30-35db so would be a lot better than the old stock fans.
I'm not sure how much room you have, but if you can fit a variable speed blower or fan that would be good so you can get the RPM down.
I put a rheostat/on-off switch in the wall as the last one was just on-off. The fans are from 1998 and being screwed into the fireplace sheet metal create a lot of noise. So much so it is unbearable. When get back in town I will reapproach the situation. -John
Yes, with those fans (115V AC) you can use those triac fan speed controls. They should have a lower limit as you don't want to reduce the voltage too much on a regular ac motor. Mounting on metal is good, as long as the metal does not vibrate. You could try new cheap motors with ball bearings, then make sure the metal frame is braced and adhesived (high heat silicone) to reduce vibration and noise)
