mikhen said:When we turn the thermostat up, the stove will lite and then go out about 5 minutes later. then if we turn the t-stat down and back up, the stove runs fine. What would cause this? I couldn't find the solution using the search bar. thanx
mikhen said:So it started doing this again. Burns for a few minutes, then goes out. If I turn the t-stat down, then right back up, it burns fine. Or if I puch the reset button, it will burn fine. Not sure what to make of it.
kinsman stoves said:mikhen said:So it started doing this again. Burns for a few minutes, then goes out. If I turn the t-stat down, then right back up, it burns fine. Or if I puch the reset button, it will burn fine. Not sure what to make of it.
Check to make sure the thermocupler is at the end of the ceramic tube and the tube is placed 1" into the pot.
Eric
Eric
slls said:kinsman stoves said:mikhen said:So it started doing this again. Burns for a few minutes, then goes out. If I turn the t-stat down, then right back up, it burns fine. Or if I puch the reset button, it will burn fine. Not sure what to make of it.
Eric
Eric How come Quad does not secure the TC so it can't creep out. I wired mine in 3 years ago, got tired of pushing it in every cleaning.
St_Earl said:wow. it's a night for the heatilator owners to come out.
i hadn't seen this thread.
good to know this stuff in advance.
i clean my baby everyday. i'll be looking closer at the tc now too.
thanks again, hearth.com compadres.
LOL@ IdahoKid's post below.
