Is this a trick question? There’s a clue in both photos
"burn things off in the flue" was a poor choice of words on my part. I agree there should never be any burning in the flue.A brush is $10 or $20, and actually cleans the flue.
"burn off things in the flue" and "chimney fire" are closely related phrases.
(This is my stock response for magic creosote removing logs and sprays, too...)
Close down the airWhat kind of stove do you have McDoug? I am a novice here and never burned but that sure seems too high to me and how would you decrease that type of temperature in order to get it down--maybe stop feeding wood or something? Do you have a fire extinguisher near for safety? Just wondering on what to do if one discover it being too high especially in the 1000 range?? clancey...
I have a Pleasant Hearth 1800, nothing fancy. I'm barely past novice stage myself, I'm still learning. The first time I hit the red zone I was a nervous wreck, till the temps settled down. I've read on here and other places, where it's ok to reach "low" high temps on occasion, depends largely on the stove and pipe. My temps last night were getting hotter than I've reached before, which is why I asked about them.What kind of stove do you have McDoug? I am a novice here and never burned but that sure seems too high to me and how would you decrease that type of temperature in order to get it down--maybe stop feeding wood or something? Do you have a fire extinguisher near for safety? Just wondering on what to do if one discover it being too high especially in the 1000 range?? clancey...
I hadn't considered the stress on the liner, that's good to keep in mind.For a long period of time, it will stress the stainless liner and is a waste of fuel. Shoot for a lower high temp next time.
Hey, it happens to all of us. It's why I have a remote wireless thermometer in front of me. Now on startup I typically run the flue temp up to about 650-700º for a few minutes, then cruise between 500-650. Today is a long slow burn so it is down to 486º for a fire started 4 hrs ago.I hadn't considered the stress on the liner, that's good to keep in mind.
The temps last night caught me off guard. I've read where some people will open the door just long enough to send cold air up the flue to bring the temps down. Is there any merit in that?
I'm building up to having her go out and scrounge for wood, cut, split and stack. Ok, that last comment won't ever happen...
With good flames, I usually keep the flue temps about 6-700º. On good coals it's usually about 400º. This is one area that I prefer to not work with ballpark numbers, what would be a good probe thermometer? You mentioned a remote wireless thermometer.Condar probe thermometers are ok, but the lag time is high so I would err on the conservative side and not take the flue temp over 7-800ºF.
My wife loves the fire and wood heat! She doesn't realize it, but she actually gets a little cranky when we don't have a fire. She's made comments about starting one when I've been out, so I knew right there, I needed to get her involved long before she tackles it on her own.Hahaha. Got a good chuckle out of that one. My wife helps run the stove when she needs to and knows what to do but I think we should settle for our wives letting us go get more wood without complaining it's taking too much space.
I have an Auber Instruments AT-210 combo wireless setup. They also make a simpler one-unit wired system. These units are instantly responsive and have a user-settable temperature alarm. They have changed my burning habits.
Close down the air
Quickest way but rarely necessary. Turning the air down will slow the fire and cool off the flue after a few minutes. I've never had to open the doors to cool off my stove and I don't think I ever would.Actually, just the opposite. If your stove is running away and too hot you need to open the doors and let cold air in. Seems wrong and I have never needed to (knock on wood) but that's the quickest way to cool the stove off.
