I've been researching wood stove for a while, looking to do some supplemental heating in our 1900 sq foot two story.mostly small rooms on the main floor which is where i'm locating the stove Plan is to do an outside chimney for space reasons. i hadn't really been looking at jotuls because of cost, but i was wandering around getting prices and the dealer had a demo model for sale so...
anyways, with the rear vent option i now have, i'm trying to figure out if its a good idea to use that and run
straight out the wall , or will this create more draft problems? i origanly was planning on a corner install , removing a small window that is there and running the flue out at about eye level, but if the rear exit will
work with this style of chimney i should have enough room to leave the window in and exit under it . should be a little less work and a little more light in the room.
I've been reading the install book, and i'm a little unclear on the required clearances that go with the rear vent option, it says 18" with single wall pipe, would that be the new required rear of stove to combustibles, or is that required vertical/horizontal etc clearances?
is the rear/ corner clearances unchanged with the rear vent? ( i plan on double wall pipe anyways)
i'm sure i will have many more questions, the site has been quite a resource for a while now, thanks
Dave
tldr; bought a stove on impulse, now have to make it fit
Dave
