Hello!  I am hoping to get some answers to our fireplace woes.  We purchased this 1993 home exactly a year ago.  We have noticed that every time we burn a fire, the house smells like ash or campfire for a few days after, despite cleaning out the ash from the chimney.  We have had the chimney inspected 2 times and cleaned once.  The inspection comes back clear, and they say that there isn't creosote build up.   Last week we had a top seal damper put on to help with the downdraft, but the problem actually seems worse since then.
Some more information:
-The chimney is along the exterior wall of a 2 story (plus attic) house, and it goes all the way to the top (no height issue).
-We live in Indiana, so the outside temperature is already cold, and it is making the chimney air cold.
-The ash smell seems to lighten during the day when the outside temp warms up, so it is definitely related to temperature.
-Since the top damper was installed, there is a cool draft that comes in.
-There is NO smell at all when the fire is lit, and we don't have trouble actually lighting it.
-The smell typically goes away after 3-4 days, though we are on day 4 with this time and it isn't showing signs of going away. This is our first fire since the top damper was installed.
Here are my questions:
-Are there any affordable solutions to this problem? We already spent a lot on the top damper, and it just made the problem worse. I would hate to keep tossing money at this to have the same result.
-Possible solutions I have come across - adding an insert with an insulated liner, just adding an insulated liner to our current fireplace, airtight doors.....any thoughts on these? I fear that we would spend $$ to add an insert and insulated liner, and would still have a downdraft issue bc we never really fixed whatever is causing it.
-Can you have downdraft issues with inserts?
Thanks so much for helping us trouble shoot this. We are pulling our hair out, and it seems that the fireplace companies we have talked to are as confused as we are.
