We just finished up installing a Harman P35i insert in my fireplace. We ran a 4" flex liner to the top of the chimney and follow the instructions (as horrible as they were) very closely. We attached the pipe to stove using 2 sheet meta screws and sealed the joint with high temp silicone. I stuffed fiberglass insulation around the pipe where it passes through the existing fireplace damper. We lit the stove and after about 45 minutes to 1 hour the smoke alarms went off in my house. I waved a towel to get the to stop, then they went off again 2 minutes later. I shut down the stove and am waiting for it to cool. Here are my thoughts - any input??
1) When we first started the stove we were waiting for the flame to start. We got impatient and restarted the process, but it seemed like the auger went through an "extra" cycle and the burn pot became very full with pellets. I can't say for sure, but it's possible some unburned, or not completely burned pellets landed in the ash tray. I'm thinking and hoping this is the issue. Maybe?
2) I put a solid amount of insulation around the pipe in the damper opening, but I didn't go super crazy. Should I pack the hell out of it?
3) We had to shift the frame around a little bit to get everything aligned after installing the pipe. Could I have damaged the seal, and could I have a bad seal on the connection to the stove frame?
Any help would be appreciated. We're eager to shut off our electric heat, but want to make sure our stove is 100% safe before we fire it back up.
Thanks!!
Thanks!!
We opened all the windows because the smell of paint n resin was very strong. After a few hrs the smell went away and the smoke alarms never went off because of the stove again.
