I currently run a Jotul F600 to heat the main floor of my home - Chalet style with an open floor plan and vaulted ceilings. It is more than adequate to maintain 74*F, even when temps dip to zero outdoors as the house in insulated rather well. Very pleased with this set-up.
I want to install a new stove in my walkout basement. It stays about 55*F without any heat. The basement has electric ceiling heat in each room with independent control(2 guest bedrooms, bathroom, greatroom, laundry). The space has 8 foot ceilings and might be 1000 sq.ft. Currently there is an older catalytic Blazeking King model installed and it will run you right out of there. The seams in the firebox are beginning to come apart, so it is time to upgrade.
The hearth is unique and doesn't permit much room to safely side-load a stove, so I need a top or front loader (that will not make a mess when loading from the front like my F600 would if I chose to do so). I prefer a cast stove, but am considering a soapstone stove. I like the gothic look that the cast iron stoves have. MUST have a glass window for fire viewing. Very impressed with my Jotul so far, but am open to trying a different brand. I cut and split 22" pieces right now - I don't want to go smaller than 20" as they get harder to stack.
Suggest away, and post pictures of your hearth and stove if you like. Thanks for the input!
