Help, our wheelbarrow died
Jack Straw
2,161
Schoharie County, N Y
I have patched up the old wheelbarrow several times and I probably could fix it again, but the wood frame is rotten. We mainly use it to move wood from the shed to the house and my wife uses it for gardening. I would like to replace it, but I am not sure what to get. We have a 2 wheeled wheelbarrow at work and I am not impressed with that. We could get a 4 wheeled cart but our indoor storage is limited. I plow snow between the woodshed and house and the lawn gets pretty rough so we need an all terrain type cart. What do you suggest?
Get a 6 cubic feet contractors wheelbarrow w/ deep heavy gauge steel tub.Can be found sometimes for $50 or a bit less.Those ones with thick plastic tubs may be lighter & rustproof,but they can crack easily in cold temps & when sudden heavy loads like crushed stone or broken concrete are dumped into them.Plus its not advised to let cut off pieces of hot rebar or other steel land in them.Dont ask me how I know this.... ;)
Alternative use for your old wheelbarrow: convert to outdoor wood boiler
  • [Hearth.com] Help, our wheelbarrow died
Those 4 wheel yard carts are a PITA if you ask me. I'd stick with a single wheel 6 ft3 wheelbarrow. Mine is poly and has been very durable. I'm not a fan of the 2-wheel-barrows either.
They sell new handles at the hardware store for pretty cheap.
The plastic tub one I have has held up fine to wood getting loaded in at -20*. Granted I don't throw it in from 30ft away either.... but yeah, it doesn't work well as a welding table... found that out too. :confused:
I like the 2 wheeler units. The farm where I cut my wood has one and if the horse ladies aren't loading it with horse chit I try and grab it to truck the logs from the wood pile to my splitter vs using my one wheeler.
Have to agree with the poly cart issues - not only can they crack but also tend to flex under heavy loads.
Spend the extra money for the long term option - steel handles and never flat tire, always hated a wheelbarrow with a flat when you need to use it
Harbor Freight firewood cart, get replacement sold inner tubes.
I am leaning towards replacing the handles, the tub and tire are in good shape.
Reactions: Jags
I replaced handles. I bought new carriage bolts (grade 5) and cut the old ones off. Made for a quick easy job. Well worth it.
If not I agree w/Thistle. I needed a smaller one for my daughters and found one on Craig's List but it took a while.
Good luck,
Mike
Where did you guys buy handles? I couldn't find any and did a terrible home-made job by splitting a 2x4.
TE
Unless you turn green when you are angry, a set of wood replacement handles should be plenty strong...I wouldn't mess with steel ones unless the price is the same or that's all you can find.
Reactions: TreePointer
2x3 Stock and a few deck screws and mine will last for another 15 years, Neighbor gave it to me when they moved, replaced the front tire and Ive been using it for 3 years already, they said they had it for 15 before I got it....
Reactions: Jack Fate
Yeah, I am going to buck the trend. I bought the 4 wheeled plastic cart from Tractor Supply with a load capacity of 1,400 pounds. The large wheels work great and I love not having to worry about balancing the thing. I would have to guess that it has moved about 4 cords of wood so far this season and I have no complaints. It even has the ability to attach to my ZTR or another tractor with a hitch, but I have a larger cart that I use on my ZTR. Have taken the cart to a couple job sites and it was great. I also use it to haul wood into the basement because it is 26" across and it fits through the door.
http://www.tractorsupply.com/groundwork-reg-heavy-duty-dump-cart-1-400-lb-capacity-1006411
Prior to the cart, I was using my dad's 25+ year old wheelbarrow that is made for carrying bricks and blocks. It looks like the last one on this webpage, but it was all wood, not metal:
(broken link removed)
Replace the handles.
Get a sled for winter / snow use
or
put in a paver brick trail, from the woodshed to the house. (level with the yard so you can mow over it ) ;)
A supporter of 2-wheel wheel barrows.
A few years ago I bought a 2-wheel wheel barrow, minus the tub. My son (works with metal) constructed a rack from 3/4" black pipe and attached it to the wheel barrow frame. The rack is 4' feet long. The front of the rack extends 2' feet in front of the wheels. The racks height is 2' feet. This thing is so well balanced that when loaded you can pick it up and push it with one hand (on good ground of course). I cut my wood 24" long so there is a good load on that cart. I just brought a load in and there's a crusty 1" snow layer on path so a liitle more difficult. Have to get out my little plow.
With this size rack (full of wood) built on a 1-wheel wheel barrow, it would be difficult, heavy, and tippy trying to bring in a big load. My distance from wood rows to house is about 300 feet.
I like the open rack concept rather than the tub because of drying. In my case my wood is damp and cold from being outside and I wheel my full cart of wood into my upper ground level wood room through a 3' foot sliding door and park it next to my wood burner. In my case I don't unload the cart. I have one of the two heat pipes blowing hot air onto the (open air) wood rack wheel barrow. If wood was in a tub, the bottom peices would take forever to dry. (been there, done that).
The pieces on top are dry and ready to burn in about 10 minutes. When you're burning 24/7 you try and find the easiest, less hassle, way of doing it.
One of these days I will post a picture of this 2-wheel wood hauler.
I have a ag-fab landscapers cart 14 Cu ft /400 lbs cap .Its got 26" bike type wheels (2) and will roll through several inches of snow .Balance the load & a small child could move it .They are a bit Pricey but this guy won"t touch a wheelbarrow any more
http://www.gardeners.com/on/demandw...s/p/36__500-Large-Gardener-s-Supply-Cart.html
We've had ours for about 35 years now and used it a lot. Works really nice for getting wood to the house too. I figured we'd have to replace it long ago but it still has even the original wood. Only thing we've ever done to it is oil the wheels. Wife also uses it a lot so you know it is easy to handle.
This is what I have tho different co. .These are great arn't they !
Those look great, but it's very muddy at my place and I am afraid those skinny tires would be a problem.
I love "dually" wheel barrrows. And yes, we have them at the barn for manure, etc.
The dual wheels are alot more stable when hauling wood, etc.
If you could only see my yard ;lol;lol ;lol you would not say that . They are mountain bike tires
I have the same cart, and use it to haul wood pellets from my shed to my house. I've carried 400 lbs of pellets at once, and was able to easily pull it uphill on a side walk. It also hooks to my garden tractor if I want to move something farther than easy walking distance. Only one year of use so far, so not sure on long term durability yet. Happy with it so far though.
We have one of these Fort brand wheelbarrows (broken link removed to http://www.tufx-fort.com/wheelbarrows/pe100/) :
(broken image removed)
Seen the highway paving guys using one at the time we were shopping and figured that if the highway guys couldnt kill it, neither could we! That was 10 years ago, and its still going strong. I should point out we live in a salt air environment and the wheelbarrow lives outside too.
That said, I think the next one will be a two-wheeler. Fort makes one, and if it's as good as the one above, Id have no issues buying it. (broken link removed to http://www.tufx-fort.com/wheelbarrows/px162/)
Reactions: Sisu
