Tube for optional igniter. If you cannot find instructions,I may have them.Just picked up a Austroflamm Integra project stove and found this part in the hopper. Does anyone know what it is or if it even belongs to the stove?
Matt
Yep. If you are not going to use it,hole should be plugged.Thanks for the Manual
Yes it's an Integra 1
Is this the hole for the igniter?
stovesandspas.com
Could be the air flow sensor.Did you clean it? I would try starting it several times, see if the results are the same. Unplug between tries.Thanks for those links Bob.
After a thorough cleaning (cleaning rods were stuck and vent holes plugged) and removal of the igniter circuit board (it had some loose wires) the stove fires and all motors work but the controls are wonky,
First off the convection fan starts as soon as pellet stove is plugged in. The switch on the control board turns the auger motor and combustion fan on but after a couple of minutes the combustion fan turns off.
The potentiometer on the control board has no effect.
I'm guessing the control board and circuit board need help.
Yep,might be the "hole" problem.Just remembered I need to plug that ignitor hole. I'm guessing having that open is messing with the airflow.
He is honest guy, and good work.He said they're definitely bad. I'll send them to have them fixed.
