Hi Everyone and anyone. I am new to this forum stuff, but have been using hearth.com for a couple years now. I purchased a new Harman wood / coal furnace model SF-2500A back at the end of 2009 with the intention of heating with wood. After hooking up the unit to the existing propane system and not getting any heat out of it to the upstairs I became so frustrated after a year and a half of trying to get this thing to work in conjunction with our existing system that I took down the duct work to the upstairs and decided to heat the basement. (There currently is a long tapered trunk that has four fingers coming off it). It works just o.K.
The question I have is. Does anyone out there have this unit that has / had problems with it. The problems I have are; 1.) Cannot keep wood in it. burns very quickly. 2.)The blower comes on and off every 5 - 10 min. The temp gets up to the required high to start the blower, then once the blower comes on, I can watch the temp go right out of the firebox within a min. or so. thereby hitting the low on the limit switch which shuts off the blower. I thought these units are supposed to blow warm steady air until the thermostat reaches the desired temp, then the blower shuts off, damper closes, and tampers the fire until thermostat calls again? The blower appears to be blowing all heat right out of firebox! It is on the lowest speed setting. It also takes 4-6 hours to get it warm in the area heated, never hitting desired temp.
3.)I can load up the firebox before bed, and get up first thing in A.M (before sun up), and there isn't a damn hot coal in the thing! I've tried shutting down the combustible air so that it burns a little slower, but it doesn't heat up the fire enough, and smokes. Someone told me to shut the bottom combustible air off completely and open the two door knob vents, b/c bottom is used for burning coal, however manual says different. I do have a barometric damper on it, but someone else told me you don't need it to burn wood....
Could the unit be defective? Called my dealer and Harman directly, and they told me that if wood burns inside the firebox, then their product is working?
I would appreciate any feedback or advice from anyone with wood burning furnace experience. I need help. paid alot of $ and getting nothing out of it.
