Hello all! I’m relative new to wood boilers (came with the 1200sqft home I purchased in April). It’s a 120k BTU hardy that is connected to my HVAC vent stack (pex to a copper radiator in the vent).
Our water heater is on the way out (incredibly 30 years old), and I’m thinking I’d like to go “tankless” and utilize the wood boiler to heat my DHW on demand (ie no hot water tank in the house).
I have a general idea on how this could be setup, but I could really use some advice on how this should be setup (as well as product suggestions on what exactly to buy).
Right now I have:
- 2 indoor thermostats (one for A/C & heat via heat pump and electric/emergency heat, another for wood boiler heat)
- a box by the hvac stack that I believe (but not certain) has to do with controlling the boiler pump (when instructed by the indoor boiler thermostat, ie not the one on the boiler that controls the boiler fan) and potentially managing the hvac fan between the two indoor thermostats
- a pump
- a supply pipe and return pipe from boiler to hvac radiator (connected to the above pump)
One way I think I could add DHW tankless heating would be to cut into the supply pipe (from the boiler), insert a plate heat exchanger that is 300K+ BTU, and then for my DHW take the cold->hot supply line, add a flow switch, run it through the plate heat exchanger, then run it through a 120F mixer.
I do a lot of DIY and remodeling, but not a lot of hvac and complex plumbing. I’m not sure exactly which flow switch to buy (guessing 0.25/0.5gpm, but dunno where to get it), how/where to connect the flow switch to have it turn on the pump without messing up the existing pump control, etc. I also feel like this setup will be a little inefficient and someone more knowledgeable could instruct me how to set it up via zones.
Thank you in advance!!
Right now I have:
- a pump
![[Hearth.com] Help with heating DHW as well as air [Hearth.com] Help with heating DHW as well as air](https://www.hearth.com/talk/data/attachments/282/282795-ce67aa09b22ffae70bbb890b07e3154b.jpg?hash=0YXNlKOmRY)
![[Hearth.com] Help with heating DHW as well as air [Hearth.com] Help with heating DHW as well as air](https://www.hearth.com/talk/data/attachments/282/282919-8dc7013a282c382cd9f47c174c56b887.jpg?hash=7Kf7gtZzaE)
![[Hearth.com] Help with heating DHW as well as air [Hearth.com] Help with heating DHW as well as air](https://www.hearth.com/talk/data/attachments/282/282920-6539fd687e0c58b0ad959568877aabf3.jpg?hash=HSpEBprzrH)
