Hey guys - based on postings/recommendations here, I've picked up a Dwyer magnehelic 2000-00 (0 to .25" WC) and attempted to check the draft on my Enviro M55-C-FS (using the port on the side of the ash pan.)
The issue I'm running into is no matter how wide open or fully closed the damper is, I'm still pinning the magnehelic at .25 whenever the "probe" (1/8" hose barb, filed down) mates with the test hole. I've tested at high heat (5) and low (1) and it makes no difference.
The magnehelic is dead level and is zeroed out when not taking a reading (it's in a stationary stand).
I'm using 5" of tubing (not sure if length could be a factor) and the Magnehelic (used from eBay) is missing the elbow barb on the back of the gauge. I also have a 2" OAK in use.
Any thoughts on what I may be doing wrong?
Thanks for any feedback and for the info I've found here in a few months of lurking!
MF
MF
